fuel line and power steering line part numbers
billy2015
05-04-2006 18:42:16
Does anybody know the part numbers for the steel fuel line between the pump and the filter and the steel power steering line between the filter and the column? Or even better does anybody have these or know where I can get these? I'd rather have the steel than the hoses. Thanks.
RodInNS
05-04-2006 19:42:33
 Re: fuel line and power steering line part numbers in reply to billy2015, 05-04-2006 18:42:16
It's just steel tubing. If you're handy with a double flaring tool and a tubing bender, then make them. The price of the OEM lines is apt to sit you down. You could probably buy the tubing, compression nuts, and the flaring kit for what the power steering line would cost. BT/DT... made the line. Just make sure you keep the anti vibration clips on the power steering lines, or they will break at the flares... HTH.
Rod
billy2015
05-05-2006 05:44:53
 Re: fuel line and power steering line part numbers in reply to RodInNS, 05-04-2006 19:42:33
Thanks.
billy2015
05-04-2006 19:47:46
I claim ignorance. What are the anti-vibration clips and what do they look like?
RodInNS
05-05-2006 11:15:39
 Re: fuel line and power steering line part numbers in reply to billy2015, 05-04-2006 19:47:46
They're just little white clips that snap onto the lines, and hold 2 lines together, or apart. However you look at it. They separate the lines, and keep them form moving around. There should be 2 or 3 of them on the supply line and the return line from the pump. They only hold the 2 lines together though. If you look in the parts book, you'll see them, and where they go. HTH.
Rod
awhtx
05-04-2006 19:23:20
It depends upon when the 5000 was built-
A) 1/1/65-9/30/68
B) 10/1/68-8/31/70
C) 9/1/70 & Later
Also, is it a standard Ag model (5100) or the Row Crop (5200)?
billy2015
05-04-2006 19:46:33
 Re: fuel line and power steering line part numbers in reply to awhtx, 05-04-2006 19:23:20
Its a january 1971 Utility.
awhtx
05-04-2006 18:47:24
It would help if we knew what model tractor you are working on.
billy2015
05-04-2006 18:59:36
 Re: fuel line and power steering line part numbers in reply to awhtx, 05-04-2006 18:47:24
oops...Ford 5000 Diesel
awhtx
05-04-2006 20:08:15
 Re: fuel line and power steering line part numbers in reply to billy2015, 05-04-2006 18:59:36
Power steering- Pressure line: D8NN3A562AA
Power steering- Return line: D8NN3B569BA
Fuel line, single filter to pump: E0NN9C330FA
I just ordered some used parts for my 1967 5000 Diesel today from Rod Rippee. rip@charterinternet.com or
(573) 431-5939
billy2015
05-05-2006 05:44:09
 Re: fuel line and power steering line part numbers in reply to awhtx, 05-04-2006 20:08:15
Thanks.
