Solution for leaking carbs
Bob Weeks
05-10-2006 18:59:07
You all know what a pain it is to shut off the gas at the sediment bowl every time you shut off the tractor. I found a solution. There is a firm in Marshall MI that sells an electric solenoid valve that only opens when the key is on and closes when the key is turned off. It can be spliced easily into the 1/4" gas line and then wired to the switch. I bought one for $39.00 a few days ago for my tractor and it seems to do just what it should. I am very pleased. Here is the number if you want to get one. 269 781 9196. It is part # ASF 121. By the way it is for 12V systems only.
