Order Ford 971 Parts Online
971 SOS FLUID
BK-PENNA
05-11-2006 13:57:35
Just drained my trans fluid from my resent purchase. It looks like auto trans fluid,actually its pink (water ? ).Is this the correct fluid or should I use the New Holland oil 134 ?
Billy NY
05-12-2006 06:36:46
 Re: 971 SOS FLUID in reply to BK-PENNA, 05-11-2006 13:57:35
I think this is the same decision my dads good friend tried to make when he decided to change the fluid in our 4000 many years ago, it did would not move after that. I'd stay with the specified fluid, I think the results you get will be much better than the above.
Doug Carmean
05-11-2006 20:37:44
I use the cheaper "universal" fluid in all my tractors except the SOS, for that I stick with NH 134.
Larry NCKS
05-11-2006 15:55:01
If memory serves, the old M-2c-41 was pink. But surely it doesn't still have that in it? NH134 or equivalent is the proper stuff for today.
Jim.UT
05-11-2006 15:15:27
My SOS tranny shop manual lists M-2C-41 Hydraulic Fluid as the fluid spec. I have no idea what that translates to in currently available fluid.
Yes, I have an SOS shop manual and no SOS tractor. I've turned into a manual junkie!
old
05-11-2006 15:40:40
 Re: 971 SOS FLUID in reply to Jim.UT, 05-11-2006 15:15:27
Jim nothing wrong with haveing manauls and not the tractor. I probably have 15-25 manauls both owners and shop type for tractors and equipment and most ar for tractors I have but not all of them
