Transmission Question
Al
08-20-2001 22:13:31
On a 62' 4000 with a 4 speed.What causes the tranny to jump out of gear when going down a hill,and what is the fix.??
Richard C. Rose
08-21-2001 15:51:02
 Re: Transmission Question in reply to Al, 08-20-2001 22:13:31
No easy fix I'm afraid Al, this is generally a result of normal wear & tear releasing the preload off the main gearbox shaft allowing the gear you engaged to move away from the engaging ring. The engaging ring then cannot work on the full surface of it's teeth, in fact, it will try to work on the ramp-in area which on over-run condition will drive the gear out of mesh.
The gearbox is recoverable from this state without renewing too much major componentry but does require a complete strip down which you could do with some advice providing you have a reasonable level of workshop equipment available to you. Best of luck
Dicko
