Order Ford 2000 Parts Online
Four Cylinder 2000 clutch
Boley
05-12-2006 23:28:50
My '63 2000 gas is going to need a clutch soon.What other parts should I replace while the tractor is apart?This will be my first time splitting a tractor and I welcome any advice from you that have done it.Thank You
Boley
05-15-2006 20:12:12
 Re: Four Cylinder 2000 clutch in reply to Boley, 05-12-2006 23:28:50
Thanks for the replies gentlemen.I wouldn't have thought of the transmission input seal and ring gear on my own.The safety tips are appreciated too,the safety issue may be what determines whether I do the job myself or let a professional do it.Either way the gear and seal will get replaced.Boley
jimNCal
05-13-2006 12:42:01
Throwout bearing for one. Input shaft seal(4 bucks) next. Time to seriously consider the merits of a Sherman Combo(available from me--SHAMELESS plug). Remember, if it can't be done safe, do it different. Work safe. Falls not only break irrepairable castings, they break human bones REAL fast and easy.
jim
MarkB_MI
05-13-2006 05:35:40
Starter ring gear. I think it's about ten bucks, which will be a lot less than the sales tax on your double clutch.
