Order Ford 901 Parts Online
901 lubricants
behrjack
05-14-2006 17:06:14
Just changed the trans oil in my 961 Im trying to give a nice fixup planning to change all fluids. Bought some SAE 90 at a farm home place it says Ford hydraulic transmission sae 90 for use in final drives, hydraulic systems, and manual trans of Ford tractors mfg between 1939 and 1952. It also says API GL-1 heres the thing it looks like moter oil thin for 90 wt just wonder if I should run it or just go get some regular old EP 90 gear oil ? And whats best in the hyd ?
Dennis (VA)
05-14-2006 18:18:46
 Re: 901 lubricants in reply to behrjack, 05-14-2006 17:06:14
You need EP90 for a 900 series in the tranny and rear end. GL1 is straight mineral oil for the 9N through 8N series.
behrjack
05-14-2006 19:10:37
 Re: 901 lubricants in reply to Dennis (VA), 05-14-2006 18:18:46
Thanks Dennis my thoughts also I just didnt think it looked right or smelled right will get the right stuff in the morning. Mike
Dean
05-14-2006 17:32:31
If it says EP-90W and GL-1 it should be fine for anything on your 961 except the hydraulics and engine. Don't forget the front pedestal.
Use CNH 135D or equivalent in the hydraulic system
Dean
Lary NCKS
05-16-2006 03:29:35
 I believe you meant . . . in reply to Dean, 05-14-2006 17:32:31
CNH 134D????? ?
Dean
05-16-2006 04:21:02
 Re: I believe you meant . . . in reply to Lary NCKS, 05-16-2006 03:29:35
Indeed I did, Lary. Thanks for the correction.
Dean
