Order Ford NAA Parts Online
Jubilee
Hulbert Keith
05-16-2006 11:12:50
What is the difference between a JUBILEE and a NAA? I bought what I think is a JUBILEE. How can I be certain it is a JUBILEE? Where is the serial number located so I can check it out?
Hulbert Keith
05-18-2006 08:28:22
 Re: Jubilee in reply to Hulbert Keith, 05-16-2006 11:12:50
SounDguy,
I looked for an hour last night for the serial number and could not find it. Does the engine have to be stripped down before the number can be seen. Is it under something like the manifold, generator, water pump etc etc? I hate to sound so dumb but I am new to this group.....I love my NAA.
Thanks in advance for the help.
souNdguy
05-16-2006 11:30:47
All jubilee are NAA.. all NAA are not jubilee.
The NAA was the model year 53 and 54 tractor. 1953 was the 50th aniversery for ford.. thus the 53 year model NAA was dubbed the jubilee. It had a different nose/hood plate. Also.. the 53's had a tranny input shaft bushing as opposed to a bearing, I believe.
The early 53's will have the sn stamped on the block at the upper left front of the engine, near the manifold. later models have the sn on a boss aft of the starter bellhousing. You will notice that both sn's for the 3 and 54 start with "NAA".
Soundguy
HULBERT KEITH
05-17-2006 15:12:07
 Re: Jubilee in reply to souNdguy, 05-16-2006 11:30:47
Is there a Jubliee club like the 8N club? The 8N club has sites showing some very nice step-by-step re-builds, shows etc etc. Are Jubliees excluded from that club?
awhtx
05-17-2006 16:07:35
 Attn: Dan from TX with the NAA in reply to HULBERT KEITH, 05-17-2006 15:12:07
A fellow named Dan who posts here occasionally has a website with extensive photos of his NAA restoration. Maybe he will see this and post a link.
souNdguy
05-17-2006 15:44:22
 Re: Jubilee in reply to HULBERT KEITH, 05-17-2006 15:12:07
Many of the early fords clubs feature the "N" series, which usually includes the 'NAA'.. which a jubilee is. This distinguishes them from the 3 digit / 4 digit hundred / thousand series. When N series was in production.. there was only 1 tractor type made at a time.. when hundred series hit.. you had many tractor models out of a couple series in production at the same time.
soundguy
Jim.UT
05-17-2006 13:55:27
Soundguy, do you happen to know how many Jubilees got the s/n on the front left of the engine block? I ask because I ran across a very original Jubilee over the weekend with s/n 12683 on the block. It is owned by the son of the original owner and has not been touched since his dad took it home from the dealer.
souNdguy
05-17-2006 15:47:05
 Re: Jubilee in reply to Jim.UT, 05-17-2006 13:55:27
12k should be on the engine.. I think as many as about the first 50k or so had the # on the engine.. can't remember.. and my ref book is not in front of me at the moment.. If I'm wAy off I'm sure someone will correct me..
Soundguy
