Ford Tractor engine?
albe
08-22-2001 05:40:38
I have a chance to pick up a 4 cylinder engine that is supposed to fit the NAA or later tractors. The cylinder head is removed. I cannot see the signs of it having cylinder liners ( no parting marks). The pistons are installed in the engine and are marked 0.030 oversize. The casting marks on the distibutor side of the engine are CONN 6015 followed by either a "G" or an "O" or zero.The bore measures out to be about 3.450 with a caliper. It does have a blockoff plate for a fuel pump and also the hydraulic pump gear. Will this work in a Ford 621 tractor? thanks albe
