Order Ford 4000 Parts Online
4000 Oil Leak
Buck
08-24-2001 20:41:03
Have a 1970 4000 that I just bought. Checked the transmission oil today and it was low. Added oil about 8 quarts and it started leaking out of the plate between the engine and transmission what could it be?
Richard C. Rose
08-24-2001 21:06:42
 Re: 4000 Oil Leak in reply to Buck, 08-24-2001 20:41:03
Transmission input shaft seal most likely, what trans type do you have?
Regards
Dicko
Buck
08-25-2001 20:36:18
 Re: Re: 4000 Oil Leak in reply to Richard C. Rose, 08-24-2001 21:06:42
Eight speed
Richard C. Rose
08-25-2001 22:44:14
 Re: Re: Re: 4000 Oil Leak in reply to Buck, 08-25-2001 20:36:18
Gearbox input shaft seals. Easy enough job but you will have to split the tractor. And remember you need to replace both trans & PTO shaft seals and it worth looking at the pto input shaft bearing while your at it.
If your clutche is OK doing this job will keep it OK. But it may already be oil effected so check it as well.
Theres something to keep you out of the wifes way for the weekend.
Regards Dicko
