Dripping 850 Carb
Andy Binsfeld
06-09-2006 20:14:20
I have a 740 with an 850 carb. I have rebuilt the carb, but still have a slow seeping problem when the engine is not running. Seems to be syphoning thru the vent for the main jet. I have tried high and low float settings but they don't seem to help. The tractor runs ok. I just have a small puddle under it every morning if I don't shut the gas off. Has anybody had this same problem and is there a fix?
MarkB_MI
06-10-2006 05:21:57
 Re: Dripping 850 Carb in reply to Andy Binsfeld, 06-09-2006 20:14:20
Check the carburetor float for leaks. Just hold it next to your ear and shake it. If it has a leak, you'll hear the gas sloshing around inside.
Most folks make a habit of turning off the gas when their tractor is not in use. Since it's a gravity feed system, any leak, no matter how small, will eventually empty the tank.
souNdguy
06-09-2006 21:08:21
First.. -ALWAYS- shut your gas off. If not you may learn what the term 'hydraulic lock' means one day... or findyourself a little low on bearing material due to gas thinned crankcase oil.
Now that that is out of the way... If you have gas getting into the carb vent/drain.. that means it is getting past the float needle/seat. That is either due to a heavy float.. a float with a hole in it.. a float that hangs.. or a bit of trash in the needle/seat area / bad or not sealing needle / seat.. etc..
Rap on the side of the carb with a screwdriver handle a fey times next time you use it and see if the drip goes away.. if not.. pull it apart again and pay very close attention tot he needle / seat issue.. It's the gas valve that stops the gas when the carb bowl is full, and opens to let gas in when the bowl is low.. float height isn't as picky as some believe.. a tad off and you will not be in a flood situation.. etc..etc..
Soundguy
Jerry Cent. Mi.
06-10-2006 04:46:06
 Re: Dripping 850 Carb in reply to souNdguy, 06-09-2006 21:08:21
Don't over look the sealing washer between the carb. body and the needle valve. It can leak and allow gas to keep entering the carb. I usually dab on some sealsall glue on the threads.
Andy Binsfeld
06-12-2006 20:27:58
 Re: Dripping 850 Carb in reply to Jerry Cent. Mi., 06-10-2006 04:46:06
Thanks for the tip. I did not put any thread sealer on the valve body threads.
To you other guys, thanks for the input, but I have played with the float, checked it for leaks, the whole bit. I even fashioned a container to fit around the carb so I could remove the bowl and see how the needle and seat behaved. Even though the needle and seat were contacting, I still had a very slow drip. I removed the carb and put light air pressure to the inlet while holding the seat solidly closed. It seemed to hold air. It may be gettin by the threads on the valve body.
Again, thanks for the input.
