Lube for tach drive solution
Brad_bb
06-12-2006 14:42:39
I wondered if white lithium grease was good enough. Then I remembered that Dremel sells grease for their flexshaft. That"s probably a harsher drive cable environment than a tach drive cable, but they are made very similarly. I bought some of the green dremel grease intended for their flex cable and used it on my tack drive cable after cleaning. Just a little tip!
GLC
06-12-2006 19:49:29
 Re: Lube for tach drive solution in reply to Brad_bb, 06-12-2006 14:42:39
I replaced mine not long ago. The new cable was dry from the package. I used 2+2 red lithium grease from an aerosol can and its been working fine for some time now.
I"m sure white lithium would do much the same.
Spraying it from the can into the cable was pretty easy and not very messy.
