need help identifying tractor
BILL NOBLE
06-15-2006 18:10:38
I recently bought what I think is a ford 800. It is an N type with an 800 emblem on the hood. Where is the serial number??? How else would I identify it. Please help. Thanks
old
06-15-2006 18:59:58
 Re: need help identifying tractor in reply to BILL NOBLE, 06-15-2006 18:10:38
The Ns as are the 600 and 800 are the series type of the tractor. Does it have a flat head engine if so its an N but if its a valve in head engine then you look on a flat spot behind the starter for the model and serail number of the tractor. It should read something like 840 if it has a 4 speed tranny etc. Or if its an 801 series it will be 841 etc
BILL NOBLE
06-17-2006 15:39:40
 Re: need help identifying tractor in reply to old, 06-15-2006 18:59:58
Thanks alot, I finally found it, not very easy to see. Model 860, serial 43075. does that sound right and is this a good tractor, so far I am loving it.
old
06-17-2006 16:01:50
 Re: need help identifying tractor in reply to BILL NOBLE, 06-17-2006 15:39:40
Not to bad of a tractor, around 40-45 HP
