Order Ford 601 Parts Online
FORD 601 12 VOLT CONVERSION
Bob Weiss
08-27-2001 08:21:42
I have checked several diagrams and can't find exactly the same setup I have. This tractor had been converted to 12 volt using a Motorcraft alternator and voltage regulator. I want to change to a 10 SI Delco alternator. I am not sure where to run the "R1" wire off the alternator. I don't want to fry the alternator. I think I have all the other connections right. I have alternator,selenoid switch,ampmeter,key (4 post) switch, starter, battery, coil, resistor, and distributor. I have no other accessories. I could fax diagram. I would appreciate the help. Thanks.
tlak
08-27-2001 12:30:19
 Re: FORD 601 12 VOLT CONVERSION in reply to Bob Weiss, 08-27-2001 08:21:42
Follow the diagram for the 12V conversion at the site Ive posted.
