Order Ford 600 Parts Online
600 lift trouble
bhb
06-21-2006 05:21:33
Hello
I have a 600 that has problems with the 3 point lift. The lift will not hold when the engine is not running. When it is running and you raise the implement to the height needed it will stay there except if the engine speed increases the lift will raise and when the engine slows down the lift drops. The draft control seems to be part of the problem. The position lever needs to be held back with a bungee cord to get the system to work. What should I look for. Thank you for your help.
Bill
souNdguy
06-21-2006 07:29:46
 Re: 600 lift trouble in reply to bhb, 06-21-2006 05:21:33
Might be multiple problems.. especially hte friction disc.. etc.
Could be leaky unload valve.. relief, and / or scored piston/cyl.
Soundguy
