crankshaft balancer
Tommy G in NC
06-22-2006 08:06:04
I have a 861 with a 172CI diesel in it without the crankshaft balancer.Can I change motor to one with balncer and still use parts off my old motor?Casting #is 310609
Hurley J. D.
06-23-2006 08:35:19
 Re: crankshaft balancer in reply to Tommy G in NC, 06-22-2006 08:06:04
What parts are you planning to use from your old motor?
Tommy G in NC
06-23-2006 10:01:22
 Re: crankshaft balancer in reply to Hurley J. D., 06-23-2006 08:35:19
I want to buy a rebuilt motor and take off parts that I will need on the outside of motor
Hurley J. D.
06-23-2006 10:47:15
 Re: crankshaft balancer in reply to Tommy G in NC, 06-23-2006 10:01:22
I did the same thing that you are trying to do. I believe all of the externals will fit on your new engine. The engine that I replaced had one of the mounting lugs for the front axle assembly broke. I had the internals from my engine put in the new (used). The used block had new pistons and sleeves installed. My old engine did not have the balancer but had the provisions for a service balancer. I found a balancer and installed in the engine. If you find a block that needs a factory installed balancer and you need the balancer then let me know I have one. The crank is different, The dipstick is different and I think the oil pickup on the pump might be, but I do not know.
Tommy G in NC
06-23-2006 11:36:26
 Re: crankshaft balancer in reply to Hurley J. D., 06-23-2006 10:47:15
Thanks for the information this will help me alot.
GLEN JONES
06-23-2006 16:46:48
 Re: crankshaft balancer in reply to Tommy G in NC, 06-23-2006 11:36:26
Tommy I have a service bal. and all the new pick up tubes everything you need accept the crank if you want e- mail your address I,al ship it to you .N- C
bjr
06-22-2006 14:29:53
 Service Balancer in reply to Tommy G in NC, 06-22-2006 08:06:04
I think I read in the book about there being a service balancer. This is one you put on if engine didn't come with one. I think there are other modification to go along with that to the bering caps or bolts, don't remember now. I don't know if they are available or not, though. bjr
john_bud
06-22-2006 10:26:53
I'm not 100% sure, but I think the only thing different is the crank. The balancer runs off a ring gear that is part of the crank. All the other stuff "should" bolt right up.
jb
