Order Ford 640 Parts Online
Removal of 640 PTO shaft
Ben.So.Tex.
06-23-2006 04:25:02
I need to remove the pto shaft on my 640 for maintance. If I take the bolts out around the pto shaft and then pull on it, will it just slip out? Or do I need to do some other steps for removal. Thanks Ben
RickB
06-24-2006 06:10:08
 Re: Removal of 640 PTO shaft in reply to Ben.So.Tex., 06-23-2006 04:25:02
Engage the PTO shifter before pulling the shaft out. Otherwise, the sliding collar will fall out of place.
Larry from Mi.
06-23-2006 04:28:20
It will slip out but you will drain the rear end.
Ben.So.Tex.
06-23-2006 04:59:00
 Re: Removal of 640 PTO shaft in reply to Larry from Mi., 06-23-2006 04:28:20
Thank You
BruceR TN
06-23-2006 15:11:39
 Re: Removal of 640 PTO shaft in reply to Ben.So.Tex., 06-23-2006 04:59:00
You'll also drain the hydraulic reservoir. If your fluids are good, drain diffy and hydraulic reservoir before you pull the pto and reuse the fluids. Could be a problem if you've got 134 in the hydraulics and 80W-90 in the diffy.
