Order Ford NAA Parts Online
1953 Ford Golden Jubilee Hydraulic Specs
andy53ford
06-24-2006 10:05:36
Does anyone know what the pressure readings should be for the hydraulics for a 1953 Ford Golden Jubilee? I have rebuilt the lift and adjusted it, It was working fine, but now it will only lift without a load on it, when you try to put a load on it it will lift just a little. I want to check the pressure but I dont know where to find the pressure specs for it. Thanks for any help.
Andy
souNdguy
06-24-2006 10:33:41
 Re: 1953 Ford Golden Jubilee Hydraulic Specs in reply to andy53ford, 06-24-2006 10:05:36
According to paragraph 116 of the FO-19 manual ( you really should get one.. ) it says:
"To check the system for maximum lifting capacity ( correct system relief valve setting ) , remove the pipe plug from the lift cover accessory plate or from lower front corner of right side of differential housing and install an oil pressure gauge of 3000 psi capacity. Anchor the lift arms withheavy chain and place the control lever in the lift position. The gauge should register approximately 2000 psi and hold steady. In tractors with a vane pump, a high reading followed by a decline in pressure indicates a worn pump. Caution, do not hold lift control in lift position for more than 10 seconds due to possible damage to the pump".
Soundguy
andy53ford
06-24-2006 15:21:42
 Re: 1953 Ford Golden Jubilee Hydraulic Specs in reply to souNdguy, 06-24-2006 10:33:41
Thank you so much for sharing the information with me, I will get me one of those manuals
