Order Ford 3400 Parts Online
Ford 3400 select o speed won't work, splines?
Lyle504
06-27-2006 10:19:39
Just bought a 3400 gas, will run but doesn"t move, took top trans cover off, nothing is turning, PTO stops and goes. Wheel locks up when I put the "tow" lever in gear, located under the seat, right side. Input shaft splines? Powershift locked up? Any help would be appreciated. Thanks.
bjr
06-27-2006 11:44:03
 tow lever in gear? in reply to Lyle504, 06-27-2006 10:19:39
I've a old 4 cylinder '64 4000 that when I bought it, it had a striped hub on the torque clutch plate. The rivets had shear off. Just be aware if that's your problem that there is differnt splines on the input shaft. I got the wrong one the first time. The lever or release shaft is what I think your talking about. It's supposed to release the wheels for towing the tractor back to the shop. Take the lock keeper plate off and turn the shaft I think like a half turn or until the wheels move free. bjr
