How to remove inlet valve seats in hydro. pump
-Mike in fla.
08-29-2001 07:44:32
Hi, i have a ford 850,i;m rebuilding the hydro. pump,what tool do i need to get the inlet seats out of pump body,i considered tapping an using a bolt an slide hammer,but someone said the seats are to hard,if thats true whats another option any help would be appreciated thanks.
Richard C. Rose
08-29-2001 15:46:34
 Re: How to remove inlet valve seats in hydro. pump in reply to -Mike in fla., 08-29-2001 07:44:32
Their not too hard Mike, 5/16unc should do the trick.
Give it a go
Dicko
JHunt
08-29-2001 22:33:26
 Re: Re: How to remove inlet valve seats in hydro. pump in reply to Richard C. Rose, 08-29-2001 15:46:34
Thats how I did mine. Wasn't hard at all. This may qualify for one of those things that people who have never done it like to tell how hard it is. Kinda like putting new ledger plates on mower guards.
-mike in fla.
09-05-2001 05:47:07
 Re: Re: Re: How to remove inlet valve seats in hydro. pump in reply to JHunt, 08-29-2001 22:33:26
DICKO&J.HUNT;ya;ll are some real WISECRACKS,some people actally expect a honest answer,you cost me alot of time and agravation,if you can;t be honest in your answers don;t brother with it!!you should think about how much money you cost people with answers like these,I:LL PRAY FOR BOTH OF YOU.
Richard C. Rose
09-06-2001 04:57:45
 Re: Re: Re: Re: How to remove inlet valve seats in hydro. pump in reply to -mike in fla., 09-05-2001 05:47:07
Wow that was a bit strong Mike, I appreciate how aggravating struggling with something you get to realise you should never have started can be.
I can assure you I have rekitted dozens of these pumps successfully and have actually made a sleeve and threaded rod tool for pulling the seats out rather than use a slide hammer, although I believe a slide hammer could work if used correctly.
I advise in this forum only on work I am familiar with and have undertaken regularly, I believe my advise is accurate and I try to make it clear but their are two variables I am not in control of:
1: The accurate discription of the symptoms
2: The level of skill and competancy of the person applying that advise to the job.
There are a couple of things you needed to work out for yourself, wether the hole needed to be opened up some more to be tapped, wether the tap was of sufficient quality to cut the steel and to recognise the difference between the valve seat and the parent housing.
Basically once advice is given you and only you must decide wether you are confident enough to undertake the work. You know you can take it down the road, pay a few extra bucks and get a guarantee. You decided to gamble and do it yourself.
Remember, advice here is free, maybe thats what it is worth to some.
Regards Dicko
mike in fla.
09-06-2001 06:05:44
 Re: Re: Re: Re: Re: How to remove inlet valve seats in hydro. pump in reply to Richard C. Rose, 09-06-2001 04:57:45
I am plenty competant thank you,I have been mechanicing for 25 plus yrs. the job was not a problem ,I needed your Idea for the tool more than "yeah they will come out" SORRY I VENTED ON YA:LL it was not very christian of me please except my apolage, mike.
