Order Ford 640 Parts Online
640 gears
AndyZ
07-03-2006 16:14:44
I have a 640 with a loader. I don't know why Ford put hotrod first and reverse gears in their tractors.My 8N is the same way. Can I swap a 5 speed in? Did ford make different ring and pinions for this? I want to slow it down so it is more suitable for loader work. Thanks
RodInNS
07-04-2006 09:42:53
 Re: 640 gears in reply to AndyZ, 07-03-2006 16:14:44
Yes, you can drop a 5 speed from a 660 right in there. That's the way I'd go if I was looking to upgrade a 600 series. The Sherman combo would work too, but you won't have live PTO from the sherman. I would look for a 5 speed with live PTO. 660 is the number. Otherwise, I'd trade up for a more useful tractor. That said, I can't imagine an application that would require a slower 1st gear than that 5 speed had. Our old 860 was so slow in first that it just never got used. Third, fourth and fifth were the main gears that got used in that tractor. I guess if you were doing a lot of over the road work, and didn't need live PTO, then the Sherman over/under would be good too. It would give you more speed on the road. Those old 5 speeds topped out around 12 mph.....
Rod
jimNCal
07-04-2006 00:16:22
Andy,
I sent you an e-mail. I have the Sherman you need. Cheaper and more versatile than the 5 speed.
jim
Jim.UT
07-03-2006 21:02:10
The 600 series was also available with a 5 speed tranny. Those were called 650 and 660 models. The same rear gears were used. I would think that if you can find a junked 650 or 660 with good transmission you could do the swap. If you're lucky enough to find a 660, change out the trans and the dual clutch so you'll also have live pto.
I have a 5 speed in an 800 series (model 850) and first gear is very slow, but I believe the 800 series has a bigger rear gear, too so a 600 with 5 speed might not be as slow as my 850.
A Sherman step-down or combo would also slow you down.
Les Lanyon
07-20-2006 21:04:26
 Re: 640 gears in reply to Jim.UT, 07-03-2006 21:02:10
If you are still looking I have for sale the comp.trans.assy.out of a 660 ford ,also have rear if needed.thanks Les
old
07-03-2006 16:35:39
Best way to do that is with a sherman combo tranny in front of what you have now. I have an 841 with a 3 speed sherman in it and low gear is so slow if you can get the traction you can watch the side walls of the tires flex under the power.
john_bud
07-03-2006 20:12:54
 Re: 640 gears in reply to old, 07-03-2006 16:35:39
Old said, "if you can get the traction"
Yeah, that's the one thing my tractor needs! It already has 3000# of BH and it probably needs 2-3000# more.
Last I checked John Smith of 8N fame had some Sherman's available. >Link
Here's>Link a link to his sherman page - good stuff there.
jb
old
07-03-2006 21:30:59
 Re: 640 gears in reply to john_bud, 07-03-2006 20:12:54
My 841 does well, fluid in both the rear tires and a back blade with 6 suit case weights hanging on it. I've push over trees 6 inches in diameter more then one with it. The loader on it is a very heavy duty one and before we had to replace the hyd pump I would pull up to a car the size of an old chev nova and pick it up. Can't do it since the pump was replaced because of the new relief valve.
