7610 ford evaparator drain
alan32287
07-16-2006 10:43:48
the ac leaks in the cab,where is the drain and can I clean it out easily?
Blue Buddy
07-17-2006 04:17:27
 Re: 7610 ford evaparator drain in reply to alan32287, 07-16-2006 10:43:48
one hose runs down each "A" pillar on each side of the windshield, black hose with an odd rubber valve thing on the end of it, take off the valve, blow back it and water should come, other wise lift the roof, or check for someone drilling holes under the fan housing (to hang a radio) that went through the water pan
RodInNS
07-16-2006 16:34:45
Dunno where the drain is, but I would suspect that if you lift the cab roof, you'll find it. Access to all the other stuff up there is by unbolting the roof, and tilting it up. That should give you an idea of what you're up against. You can clean the heater core and evaporator while you're in there. HTH.
Rod
alan32287
07-20-2006 15:05:14
 Re: 7610 ford evaparator drain in reply to RodInNS, 07-16-2006 16:34:45
thanks,fellows,I think I have the problem fixed.
