Order Ford 4000 Parts Online
4000 ford bearing growl
3gfarms
07-29-2006 19:51:28
I recently purchased a late 60"s 4000 diesel
with an 8 speed gearbox. it has a very heavy growl when the cluch is out. If the clutch is
depressed the noise stops & it does it in all
gears as well as nuetral.you can feel it in
the tractor,, any ideas or help!!!!!
sotxbill
07-31-2006 07:36:38
 Re: 4000 ford bearing growl in reply to 3gfarms, 07-29-2006 19:51:28
every 4000 I have has done that...
but... drain the trans and refill to get rid of the water that has migrated into the trans...
john in la
07-30-2006 08:18:13
Since it also does it in netural It has to be on the input side of the trans.
The most likely bearing is the input shaft bearing.
souNdguy
07-29-2006 21:04:52
Not much help.. but I'd say it soulds like a bearing int he trans is gone. Pull the top cover for a looksee / maybee you will get lucky and see an obviously loose shaft.. or shelled bearing..etc..
good luck
Soundguy
