Power Steering Oil Cooler
bjr
08-01-2006 09:27:03
I have a '64 4000 LCG w/172D engine and SOS transmission, and would like to know if they came with power steering oil cooling of somekind? Would a air style cooler, aftermarket kind, mounted in front of radiator be a good idea or is it necessary? This is the two cylinder steering system. bjr
Dean
08-01-2006 13:36:40
 Re: Power Steering Oil Cooler in reply to bjr, 08-01-2006 09:27:03
BJ:
Your tractor was not designed with an oil cooler for the power steering system, and none is needed. That said, I do not suppose that adding an aftermarket oil cooler would hurt anything other than increasing the number of connections that might someday leak.
Now, an oil cooler for the S-O-S like that on the 65 and later models would be an improvement.
Dean
souNdguy
08-01-2006 12:03:33
Not specifically your tractor.. but I do recall seeing some finned lines with a cooling block.. though don't know if this is oem or aftermarket.. etc.
Soundguy
Hurst
08-01-2006 19:40:28
 Re: Power Steering Oil Cooler in reply to souNdguy, 08-01-2006 12:03:33
Thats what our 6610 and 7610 have on the powersteering for cooling. It might fit on a 4000? Good luck!
Hurst
souNdguy
08-01-2006 20:26:07
 Re: Power Steering Oil Cooler in reply to Hurst, 08-01-2006 19:40:28
That must be where I have seen them.. on some 6610 at the auction.. was only a couple loops and some fins... but guess it couldn't hurt.. as long as you could make it fit.. etc..
Soundguy
