Order Ford 9N Parts Online
9n ford tractor
1940
08-03-2006 11:53:49
hello - Doe's any one know what type of rear end fluid goes in the a 1940 9n rear-end and how much,thank you for your time Jeff
Tim K
08-03-2006 20:45:26
 Re: 9n ford tractor in reply to 1940, 08-03-2006 11:53:49
Old is right. I tried to use #`134 in my 2n and quickly found out that once it got hot and really thinned out, the lift wouuld not work right, even with the new hydraulic cylinder I installed. Suggest you go to NH who may have the 90 wt mineral oil (mine did). If yuou use the #134 I guarantee that you will be changing it twice with about +$50 down the drain.
Dan
08-03-2006 13:48:20
Original Ford specs are 90w Mineral Oil (which can still be found at NAPA stores and most Tractor Supply Stores), or the modern substitute is 90w GL-1 gear oil. The New Holland spec changed that to a 134d compatable hydraulic fluid, but I prefer the thicker stuff as it finds leaks less. Of course, I live in Texas - so if you live in real cold climates the thinner 134d will help your hydraulics work better in the Winter.
Your call.
Dan
old
08-03-2006 12:09:05
Just a little bit less then 5 gallions, something like 4.5 gal. It should be mineal oil GL some thing or the other don't have the extact info on hand. Look down one forum there was just talk about it this morning and theres a post that has that info from today
