Ford 671
Arnold b
08-05-2006 13:18:25
I have a early 1960's 671 diesel seleto-speed...It has not ran since 1980...Been in the back of the barn covered up...It will turn over by had...my question is would you tear it down or just just try to get it running....
Bobrh
08-05-2006 17:14:58
 Re: Ford 671 in reply to Arnold b, 08-05-2006 13:18:25
About three years ago I found and bought an 871 and a 671 low hour tractors (gas) that had set for about ten years. After changing all engine fluids, replacing plugs, points they both started and ran ok. Local tractor ford/fordson club members told they would run fine for about ten hours if they had set without running for years.
Anyway they were dead on because at about ten hours the head gaskets started to leak badly and the water pumps both leaked. The 671 also needed front and rear main seals, plus the little governor cover seal. Both tractors run fine and the only recent seal that went was the steering box a few months ago on the 671(power steering fluid running out the vent hole)that was not that difficult to replace although time consuming.
dan hill
08-08-2006 16:07:01
 Re: Ford 671 in reply to Bobrh, 08-05-2006 17:14:58
some friends and I got hold of an old Model A that had been sitting for 10 years with a cracked head.We replaced the head and the A ran good for for 17 years with no problems. Dont beleive a thing you hear or half of what you see.
old
08-05-2006 14:47:28
I would drain the oil and change it and also maybe pour a little tranny fluid or oil in the intake and turn the engine over at the same time. Do it very slow to keep from getting a hyd lock but do it long enough to help loosen up the rings and also to lube the cylinder walls. Also drain the old fuel and chenge the feul filter and then I would go it a go and see it it still runs
Feron
08-05-2006 13:45:33
I think I would try to get it running first.
