Order Ford 4000 Parts Online
early 60s Ford 4000 push button start
Robin Mizell
08-10-2006 05:06:17
What is the wiring diagram for the Ford 4000 push button start? It is a single wire system. This is for a friend. He says it is between a 60 - 64 model.
john in la
08-10-2006 08:23:23
 Re: early 60s Ford 4000 push button start in reply to Robin Mizell, 08-10-2006 05:06:17
third party image
This wiring is for the stock 6v system used on pre 65 2000/4000 and 601/801 tractors.
Make sure you have a tractor starter relay as the car relay will not work.
john_bud
08-10-2006 06:35:44
Yes, single wire. It is a normally open switch and when closed, allows an electrical path to ground. Be sure you get the correct relay, it's not the same as a ford car starter relay -- has to be for a tractor.
jb
