Order Ford 4000 Parts Online
4000 power steering
bjr
08-20-2006 12:02:30
Just got the old 4000 diesel SOS running, the model that looks like the 800 series. I had traded for this non running old tractor hoping the SOS would come back to life, and it did. All 10 speeds, both reverse and nuetral and park are there, Hooooray. A detail that I do have to address, though, is the power steering cylinder ends rub the tires when turned sharply. Should I try to find a adustment to make the PS cylinder bottom out before coming up on the stops down on the spindles? I don't know how to make it not turn so sharp. What should I do? bjr
souNdguy
08-21-2006 05:23:28
 Re: 4000 power steering in reply to bjr, 08-20-2006 12:02:30
Are your front rims turned in to a narrow position. And not sure if your axles can be adjusted oor not.
Soundguy
bjr
08-21-2006 06:36:04
 Re: 4000 power steering in reply to souNdguy, 08-21-2006 05:23:28
Yes, and I have those half moon weights on the inside of the front rims. I was out on the road testing the transmission and one of those weights slipped a little and stuck out enough to come in contact with the spindle. What a racket, I thought the whole machine had blown up. I nurse it back into the shop and jack up the front end and found the problem. Not much clearance there. bjr
