Order Ford 971 Parts Online
971 -Power steering
BK-Penna
08-21-2006 13:34:49
When I fill my power steering reservoir up with fluid (not overfilled) and turn the wheel,fluid shoots out of the hole on the cap. This continues until a bunch of fluid has come out, and the dip stick says I am low. Is the cap bad, or do I have another problem? I tried to order a new cap,but they are not available.
B. Jones
08-21-2006 16:54:22
 Re: 971 -Power steering in reply to BK-Penna, 08-21-2006 13:34:49
I also own a 971 and have had the same problem. I also agree with HB. Replace the round filter in the pump. I just read your post again. You have a dip stick. My pump does not have a dip stick. There is a big ring and the whole top comes off the pump. Does your top come off so that you can see the filter? B. Jones
BK-Penna
08-22-2006 03:20:25
 Re: 971 -Power steering in reply to B. Jones, 08-21-2006 16:54:22
No-Mine opens at the end. Thanks for your help!
~~HB~~ in NC
08-21-2006 14:38:44
Hi BK-Penna,
Replace the filter. It looks like a big fat donut. This should solve your problem.
~~HB~~ in NC
