Order Ford 861 Parts Online
861 Ford rear end
auten
08-21-2006 20:27:27
I"m at a loss.I have an 861 that keeps stripping the rear end housing bolts out on the clutch side. It does have a loader,but,it does it even under no strain(just drive it a little and it happens).Any thoughts or ideas?
Dave H (NY)
08-22-2006 14:39:23
 Re: 861 Ford rear end in reply to auten, 08-21-2006 20:27:27
It sounds like a bent axle or bad carrier bearings in the differential. That housing should not have any torsional stress that should cause that to happen.
john in la
08-22-2006 09:37:13
third party image
Sounds like you mean these bolts.
And I assume the bottom studs is the ones you are having problems with.
So is the nut comeing off the stud or is the stud pulling out of the center housing????
If the nut is coming off you need to replace the studs.
If the studs are pulling out you got real problems and will most likely need to helicoil it to fix it properly.
Dave H (NY)
08-22-2006 04:51:28
Which bolts are you refering to? Are you talking about the bolts around the axel housing?
auten
08-22-2006 09:19:11
 Re: 861 Ford rear end in reply to Dave H (NY), 08-22-2006 04:51:28
Yes,the round housing that bolts to the center rear end housing
