Order Ford 2000 Parts Online
ford 2000 select-o -speed
bob reiter
08-22-2006 05:07:02
i have a selectospeed in my 2000 and was brush hog and all at once it stopped moving no matter what gear i selected at low rpm it would not move but if i increased rpm to appox 1300 or more every gear worked good. the fluid levels are good can anyone tell me what the problem is?actor is my favorite so i do not want it in the bone yard yet.please help me as i am totally lost.
RICKWI
08-22-2006 20:18:54
 Re: ford 2000 select-o -speed in reply to bob reiter, 08-22-2006 05:07:02
What happens when it all cools down and the oil viscosity thickens back up? What is in there for oil, and when was the filter last changed?
Larry NCKS
08-22-2006 13:20:59
First off which 2000 is it? Is it an early 4 cylinder or later 3 cylinder?
At any rate, you've lost pressure at low RPMS for some reason. If you were to run the pressure checks at all servos and in all gear ratios, it would give us more to go on.
Did the PTO and shredder keep the normal pace or did it quit at low RPMS too?
My guess is that you have a ruptured seal on the main pressure line, but there are about five other things that could cause this besides low oil level. Is your inlet screen restricted by any chance?
bob reiter
08-25-2006 10:24:16
 Re: ford 2000 select-o -speed in reply to Larry NCKS, 08-22-2006 13:20:59
to reply to your questions the pto stayed running in both low & high rpms. its a 4 cly gas model i have not done any pressure checks as of now but i will do some in the near future so please do not lose faith in me yet as i do need help in solving this.
souNdguy
08-22-2006 07:17:59
There are a couple guys here that are the forums SOS experts.. I'm sure they will be along in short time. My non-sos experienced guess is an internal leak that is bleeding off pressure to some important part.. like a clutch pack / servo .. and not letting it engage untill you rev the engine up enough to get more pump rpms to overcome the leak.. etc..
That's a WAG.
Soundguy
