Order Ford 600 Parts Online
600/800/801\601/2000 Cylinder Head
DonCam
08-24-2006 14:10:45
Are the 600/601/800/801/2000 Gas cylinder heads the same. The part number on the head is 310098. My parts manual doesn't cover the 01 or thousand series so that part number isn't listed. I show a 310097 and 310099 and these two heads appear to fit both the 134 and 172 engine. I would assume them to be the same unless the 134 had smaller valves and intake/exhaust ports.
I know some heads has holes for 7/16 bolts while others are for 1/2 inch. I assume there are some sleeves available to used a 1/2 head on a 7/16 head.
Thanks Don
jmixigo
08-25-2006 09:50:18
 Re: 600/800/801\601/2000 Cylinder Head in reply to DonCam, 08-24-2006 14:10:45
These heads are not the same, but they are interchangeable. The BEST solution is a good used head off of what you have. The new aftermarket heads available now are a "one fits all".
bjr
08-26-2006 08:13:52
 One head fits all? in reply to jmixigo, 08-25-2006 09:50:18
Do you know if there's a head for the 172 Diesel available? Where could I look for one? bjr
