Order Ford 9N Parts Online
9n Wiring
billsuekidsncows
09-01-2006 15:06:10
Got a 41 9ner , it was running when I got it, now refuses to fire, carb has been done, must be spark/
I HAVE INSTALLED A NEW SWITCH AND AMP GAUGE, MAYBE I MESSED UP THE WIRES. hARNESS IS RATTY AND TAPED, ANYONE WITH A WIRING DIAGRAM AND ANY IDEAS? + OR - GROUND?
billsuekidsncows
09-16-2006 12:07:26
 Re: 9n Wiring in reply to billsuekidsncows, 09-01-2006 15:06:10
Thanks to all for the help, finished off the rewiring job, popped in the new switch and coil, hit the switch and choke, purred like a kitten, after sitting for close to 3 years. Little black smoke for 30 seconds or so.
The relay for starter buzzes when I hit the pushbutton on dashboard, normal? or do I have a 12 volt relay? Or is my 4 year old battery getting low? Ammeter is showing negative charge, can they be wired backwards?
billsuekidsncows
09-03-2006 15:33:05
Did a complete rewire, Thanks for info, still no spark, wired around "new" switch, still spark in old girl. New switch was defective. Went to Canadian Tire, got one that works fine and looks like original. It is still 6V , but coil is old, will install new coil. Could switch it over to a 12 voly system, but like idea of keeping it Original ,ran 60+ years that way, few more can't hurt, Thanks again----Bill
Bob
09-03-2006 04:26:43
Have you figured it out, yet?
Third Party Image
If it's "as original", and hasn't been converted to 12-Volts, or been changed to a generator with a voltage regulator, this diagram should be what you are looking for.
Bob
09-03-2006 04:26:39
Third Party Image
