Order Ford 4000 Parts Online
4000 electrical
77 shovelhead
09-01-2006 19:29:56
My 4000, 3 cyl. diesel has a few wires hanging under the dash, along the steering column that is not connected to anything. Also there are a few components that I don't know what they do.
1. Mounted under the dash on the left side is something made by (HELLA). There are two numbers on it TBB 38 and 4DN003438-18 with six blades, for wire connections, on the bottom. What is it and what does it do?
2. On the right of the dash is a key switch that looks like the starter switch but the back is different. It’s made by (BOSH) with two screws and five blades for wire connections on back. My key fits in but won't turn it. What is it and what does it do?
3. On the top right of the dash there is a small light (no cover). The back is about 1-1/2" dia. with eight blades for wire connections. Again, what is it? 4. On the top left there is an aluminum housing with three red light covers. There is nothing inside it or connected to it. What was this cover for?
tsix
09-04-2006 16:03:13
 Re: 4000 electrical in reply to 77 shovelhead, 09-01-2006 19:29:56
Not sure if this will help, but with out the year and all it is all I can offer.
tsix
09-04-2006 16:03:55
 Re: 4000 electrical in reply to tsix, 09-04-2006 16:03:13
third party image
Lets try this again
77 shovelhead
09-08-2006 20:45:45
 Re: 4000 electrical in reply to tsix, 09-04-2006 16:03:55
Thanks tsix, your drawing helped. It is my belief that I have a mid 60"s 4000, 3 cyl. diesel. The battery acid has removed the numbers behind the starter.
I made a hand drawn diagram before removing any of the components but left it out and it got rained on and now I"m screwed, unless someone has more information.
77 shovelhead
09-03-2006 20:44:32
Ok I figured out that the housing with the three red light covers is probably something to do with turn signals. Did the light switch require a key to operate?
Come on guys what is the other stuff?
