Leaking injector pump
806man
09-04-2006 13:05:14
I have a 3600 Ford utility tractor that has developed a leak in the top of the injector pump. (where the throttle is attatched) is this an item I can repair myself or do I have to get a new injector pump??? Thanks in advance!!
JF in CT
09-04-2006 14:54:02
 Re: Leaking injector pump in reply to 806man, 09-04-2006 13:05:14
I just discussed the same thing with someone in the MF thread. If it is a CAV I put the guy onto several sites with photos. If you can't find it just email me. Oh, btw I did mine and if you are carefull it will only cost you a gasket and several o rings.
Jim
J Schwiebert
09-04-2006 14:41:03
Look over on the M-F form or find me on the Oliver form. I would guess you have a CAV model DPA pump or one that is a look alike. It was discussed recently on the M-F orm and years ago when I did this for a living I did some 354 Perkins in Oliver 1850 tractors. There are a couple of cautions that you need to observe. Money wise I think $20.00 should fix you up. Questions send me a note. I am going to send you an e-mail as well. However I will be out of town on business the last half of the week. J.
