555b torque converter problem
andrew hull
09-10-2006 04:35:05
I recently bought a 555b, 1987 w/ shuttle shift. It has a hard time moving in anything but 1st gear, and labors heavily going up inclines. The RPM's are way up but it barely moves. Everything else works fine. Could this be the torque converter? Thankfully I did not pay alot for the unit so fixing it is in the budget. I would appreciate any help!
andrew hull
09-10-2006 04:39:14
 Re: 555b torque converter problem in reply to andrew hull , 09-10-2006 04:35:05
I forgot to post that I did check the transmission fluid and it was pretty low, I did fill it and it did not do much of anything (slight improvement)
jml755
09-10-2006 06:42:46
 Re: 555b torque converter problem in reply to andrew hull , 09-10-2006 04:39:14
Did you check/change the transmission fluid filter? Also, there should be a port on the side of the pump where you can check clutch pressure. If you don't have a Service manual, I'd start by getting one.
andrew hull
09-10-2006 18:06:30
 Re: 555b torque converter problem in reply to jml755, 09-10-2006 06:42:46
I haven't changed the filter, but I do have a manual. I will start with the filter and see if that helps.
andrew hull
09-13-2006 04:09:35
 Re: 555b torque converter problem in reply to andrew hull , 09-10-2006 18:06:30
So far I replaced the transmission fluid filter with no results. I guess I will check the clutch next.
