Order Ford 4000 Parts Online
cotter pin in 4000 bellhousing?
77 shovelhead
09-10-2006 19:54:15
1965 to 1968 Ford 4000 diesel 3cyl. 8 speed
Does anyone know what the cotter pin sticking out of the bottom of the transmission do? I was filling my transmission with oil when I noticed oil dripping from this cotter pin.
77 shovelhead
09-12-2006 14:40:25
 Re: cotter pin in 4000 bellhousing? in reply to 77 shovelhead, 09-10-2006 19:54:15
After I removed the overflow plug and drained about a pint of transmision oil it stopped dripping. I have it all back together and all seems fine now.
Thanks for the help.
mowr
09-11-2006 17:57:56
I'm sure you wouldn't do this but someone told me he used regular motor oil ('for gasoline engines') in his diesel tractor. He also commented that he was losing a lot of oil out the rear main seal. I advised him that what he was using is not designed to meet the requirements of diesel engines. After changing to diesel motor oil, he told me that the oil loss had dropped to insignificant.
john in la
09-10-2006 20:03:33
The hole is a oil drain for the clutch area.
The cotter pin keeps the hole from pluging with dirt and oil.
If you see oil driping you have a rear main engine seal or a trans input shaft seal leaking.
77 shovelhead
09-10-2006 20:28:19
 Re: cotter pin in 4000 bellhousing? in reply to john in la, 09-10-2006 20:03:33
Thanks John.
jmixigo
09-10-2006 21:05:57
 Re: cotter pin in 4000 bellhousing? in reply to 77 shovelhead, 09-10-2006 20:28:19
Good thing it's in there cause you gotta split the tractor to replace it.
Larry NCKS
09-11-2006 04:19:02
 Split the tractor . . . in reply to jmixigo, 09-10-2006 21:05:57
just to replace the cotter! Surely you jest! I could crawl under and clean the hole many times before splitting a tractor just to replace a weep hole cotter.
jmixigo
09-11-2006 04:51:22
 Re: Split the tractor . . . in reply to Larry NCKS, 09-11-2006 04:19:02
Why certainly I jest. A cotter pin whose sole purpose in life is to occupy space so crud can't go there? Yet the only way to replace it?
I did not think LOL was even needed.
