Fuel Gauge Problem
Bigblue
09-18-2006 04:12:15
I have a 1970 Ford 4000. The fuel gauge has worked sporadically for last few years. I discovered that the ground wire from the top of the sending unit in tank was missing. I tested a connection from there to the negative ground terminal on the instrument cluster and it worked.
But then after two days of working it stopped working. Rechecked ground and it still doesn"t work. Any ideas?
Dan Monigold
09-18-2006 10:23:25
 Re: Fuel Gauge Problem in reply to Bigblue, 09-18-2006 04:12:15
Does your temp gauge work right?
Bigblue
09-19-2006 17:13:21
 Re: Fuel Gauge Problem in reply to Dan Monigold, 09-18-2006 10:23:25
yes it works fine.
Dan Monigold
09-20-2006 06:28:51
 Re: Fuel Gauge Problem in reply to Bigblue, 09-19-2006 17:13:21
Just checking , When my fuel gauge was acting strange I also notice that my temp gauge was always reading slighty high . After checking the everthing else it turned out to be the voltage stabilizer (60$)
Dan
