serial nos.
Barry D.Watson
09-22-2006 15:21:59
85112585,eaf6015j best i can tell these are from a 801 power master.can anyone give some info on these? Thanks.
awhtx
09-22-2006 19:54:03
 Re: serial nos. in reply to Barry D.Watson, 09-22-2006 15:21:59
It looks like you have combined your model number and serial number. It appears you have a model 851, serial number 12585. The number starting with EAF is the casting number from your engine block and it designates the 172 cu.in. engine. I believe the 134 cu.in. engine is cast with an EAE number. It appears that you do in fact have an 801 series Powermaster, specifically an 851.
OLIVERJIM
09-24-2006 13:19:30
 Re: serial nos. in reply to awhtx, 09-22-2006 19:54:03
Could you tell me where to look for the serial number on a Ford 881? Thanks, Jim
Larry NCKS
09-23-2006 04:09:59
I'm impressed! My light bulb sure wasn't shining that brightly.
Larry NCKS
09-22-2006 19:20:58
Those are not serial numbers off an 801. An 801 serial # would be 5 or 6 digits and located on the flat on the bellhousing behind the starter and under the air cleaner. The model number would also be there. It would read 8*1. The * could be any number from a 1 to an 8 depending on transmission, PTO and several other options. There could also be diamonds around this number and a few different suffixes such as D for diesel.
