Order Ford 600 Parts Online
Ford 600 hydraulic lift wont lift HELP!!!!
Adam Davis
09-12-2001 19:53:26
My 1955 Ford 600 Hydraulic lift wont pick anything up that is over a certain number of pounds I cant even get a 5x6 round bale off the ground more than 1" I think I may need to replace the pump it acts like it wants to pick it up but it wont.
DonP
09-14-2001 15:20:31
 Re: Ford 600 hydraulic lift wont lift HELP!!!! in reply to Adam Davis, 09-12-2001 19:53:26
This may not be a valid test, but try this:
bring the arms up without anything on them (I assume they will do that?)
Turn the tractor off. Do they drift back down within a couple minutes?
Mine did. I replace the seals in the big piston under the cover the seat bolts to, now I can lift my 7-foot dirt blade all the time, while before, it had gotten so I could only do it when the oil was cold, and didn't have to mess with the pump.
For a more complete trouble-shooting procedure, check out the I&T FO-20 manual.
Hope this helps.
