hi Dave, The 'slow to Park' glitch is definitely caused by the interlock cover, which has three valves to sychronize the application/release of Bands 2 and 3, specifically for the shifts beween four and five. Like Texadian wrote, the interlock is supposed to prevent the transmission from momentarily going to Park. As an example, when pressure is applied to Servo 3 and the piston moves, the small valve pinned to the piston rod is withdrawn from the interlock cover which opens the oil exhaust passage for the Servo 2 piston. When doing pressure tests, I only moved the selector one position at a time--would have been better to experiment like you did. The gauge needle rose and fell instantly at all three servos, in all lever positions EXCEPT at Servo 2 when shifted from R2 to Park--pressure bled off slowly. My transmission locks in Park immediately, regardless of how the lever is moved, or whether the engine is running or stopped.Off the subject a bit, manuals contain mistakes. I&T FO-20 is all screwed up. The 'Pressure Gage (sic) Readings' chart shows 180 psi to Servo 3 in R2, which is impossible. If the C carrier isn't held by B3, power can't be transmitted in a reverse direction. The 'Trouble Shooting Chart' uses one asterik to show spring-applied units (B2 and B3), and two asteriks to show pressure applied units (B1 and the clutches): The chart and the chart instructions contradict each other. I've also found at least one mistake in the SOS section of the Ford manual. Makes it interesting for the amateur. Pressure at Servos 2 and 3 in Neutral is a real puzzle. Some will think this is ridiculous, but I believe a cam was installed wrong at the factory. After all, with B2 and B3 released, the transmission does actually go to Neutral. In a discussion a while back, the man had two SOS tractors and could look at both control valves side by side. I don't remember any details, but it had to do with Nine and Ten, and the cams were different. Well, I've made a long-winded post and provided absolutely no help. Is your transmission still on the test stand?
