Order Ford 640 Parts Online
640 PTO won't enguage ( HELP )
Ben.So.Tex.
10-02-2006 08:24:30
I try to remove the PTO shaft on my 640 and it would only come out about 2 inches. The pto lever would move when trying to remove the shaft. So I left good enought along and put it back together. Now my PTO won't stay in gear It work fine before I messed with it. What did I get out of line? All I wanted to do was replace the leaking PTO seal.
Help me if you can. Thanks Ben
DonCam
10-02-2006 13:50:04
 Re: 640 PTO won't enguage ( HELP ) in reply to Ben.So.Tex., 10-02-2006 08:24:30
Pull your shifter cover off and see what's going on in there. You might have to drain some oil but you will have a very good view on the PTO shaft and the shifter sleeve.
