Order Ford NAA Parts Online
1953 Jubilee PTO problem.
Bev Hutchinson
09-15-2001 09:07:08
The 3-point does not lift...Has a Vickers Vane Pump which has been gone over and is ok. Does anyone have a diagram of lift mechanism? For a while is jumped out but will not do anything now. Help? Thanks
Mike OH
09-16-2001 18:21:19
 Re: 1953 Jubilee PTO problem. in reply to Bev Hutchinson, 09-15-2001 09:07:08
I had the same problem with my Jubilee. Took the lift cover off from under the seat and found the gasket was torn. Didn't look like that would be the cause but I replaced the gasket and it has worked fine ever since. Check out the link for a wealth of information on the Jubilee and other Ford Tractors. Good luck.
