Order Ford 4000 Parts Online
4000
Shawn
09-16-2001 17:29:19
I have a Ford 4000 with a spindle stuck in the steering. I've heated the housing, oiled it well and beat on it with a very large hammer. Any suggestions on getting this thing out? It does not turn. My guess is the bottom bearing is rusted on. Other than a new part. Could something be bent? It doesn't appear to be.
Richard C. Rose
09-17-2001 05:24:00
 Re: 4000 in reply to Shawn, 09-16-2001 17:29:19
Shawn, could you be a little bit more specific.
Which steering, power or not.
Which spindle, king pin or steering shafft.
Regards Dicko
shawn
09-17-2001 15:08:04
 Re: Re: 4000 in reply to Richard C. Rose, 09-17-2001 05:24:00
king pin. THe vertical shaft that the drag links attach to.
Richard C. Rose
09-18-2001 18:10:40
 Re: Re: Re: 4000 in reply to shawn, 09-17-2001 15:08:04
They can be tough alright.
You need time to soak them so that the penetrating oil can really do its stuff. I overhaul a lot of factory equipment from a very wet and corrosive enviroment and I have found that CRC is really good stuff, but it needs 4 days to work. I'll spray a bearing on a shaft everytime I walk past it for 4 days and the bearing, which I know from experience would be impossible to shift at first, will move OK after that time.
This is not a CRC plug, I'm sure other product would work, even soaking it in diesel or kero, its the time that has the most effect.
Good luck Dicko
shawn
09-17-2001 15:07:57
