Order Ford 4500 Parts Online
ongoing saga 4500 trans
a4t1rat
10-23-2006 12:38:13
Hi all.
I have been trying to figure out my 4599 power reversing trans problem.. have another question.
this trans has no forward, reverse works fine. do the blocker valves have anything to do with this operation as mine are appearently not working. i can move the shift lever any time weather tractor os running or not. also someone has messed with them before because dash and steering wheel are still loose. or is this something else that needs to be fixed. any help would be appreaciated also where is the forward clutch located? behind the converter/pump? Thanks Gordon
JF in CT
10-23-2006 16:08:30
 Re: ongoing saga 4500 trans in reply to a4t1rat, 10-23-2006 12:38:13
I seem to remember that mine won't shift (reverser)when its not running and definately won't select F or R unless below 1200rpm or something like that.
Jim
