Order Ford 9N Parts Online
9n very weak spark
arnnesa
10-26-2006 19:02:32
need help replaced everything but coil changed over from 6v to12v very weak spark will not start
Tim K
10-27-2006 06:34:35
 Re: 9n very weak spark in reply to arnnesa, 10-26-2006 19:02:32
you should have 3.5-4.5 volts at the coil with points closed. If more, you burned up the coil.
old
10-26-2006 20:15:48
Are the points set right?? Also did you put a ballast resister in the system?? If you didn't you may have burned out the coil and if so you will have a weak spark if any
