Order Ford NAA Parts Online
Jubilee axle nut
bay734
11-16-2006 15:16:12
I am having trouble tightening the rear axle nut to 450 ft lbs torque per specs. I don't have a socket that large and my torque wrench max. is 150. Also when I tighten it with an adj. wrench I can't tighten it enough to line up the ring keeper and the slot.
Keith Weber
11-20-2006 11:22:30
 Re: Jubilee axle nut in reply to bay734, 11-16-2006 15:16:12
I have the same problem with my Jube. I did purchase a 2" socket but can't quite get to the notch for the keeper. What-to-do?
DRWNY
11-17-2006 04:48:48
Many air impact guns will torque this high,if you have access to one.
Jim.UT
11-16-2006 20:55:40
I found a 2" socket at a pawn shop. Paid the man $5 for it plus a Ford script end wrench and a couple of screwdrivers.
450 ft/lbs would be 450 lbs hanging off the end of a 1 foot long breaker bar. Or 225 lbs hanging off the end of a 2 foot breaker bar. How much do you weigh? Divide that into 450 and that's how long a breaker bar you need. Sit all your weight on the end of that bar.
Dean
11-16-2006 16:59:06
Bay:
You will need to buy or borrow a bigger wrench or socket for this job. It is important that this nut be properly tightened in order to avoid damage to the hub and/or axle.
Large combination wrenches suitable for this job are available from Harbour Freight for an affordable price.
Dean
