5550 ford back hoe
bigomike
11-21-2006 10:57:56
i have a 5550 ford back hoe,im looking for the id plate, also if anyone can help the hydralics on the hoe and buckek move slow ,im trying to find out if there are any check valve and where they are located
john_bud
11-22-2006 20:16:48
 Re: 5550 ford back hoe in reply to bigomike, 11-21-2006 10:57:56
Big,
You really need to invest in a set of manuals for the machine. If $$ is tight, you may be able to get a copy thru the library. Or even a page or two from your local FNH dealer.
While I don't know about your machine exactly, in general, there is at least one relief valve in the loader control and probably 4 or so in the BH control valve.
You can get a 0-3000 psi gage from Napa (or others) and then measure where the pressure maxes out. If it is slow all the time, a couple things can be the root cause. Stuck relief valve dumping all the fluid or the pump is shot.
jb
