Oil in Coolant
backhoeken
11-21-2006 17:08:33
This is my first post in a long time.
Anyway I have a 755 and just found a light skimming of oil in my radiator. No water in the oil.
The tractor is a 755 diesel 4 cyl. Any ideas
bent3
12-09-2006 15:16:20
 Re: Oil in Coolant in reply to backhoeken, 11-21-2006 17:08:33
Does the radiator have a oil cooler in it if it does that is probally the problem i have 10 7610 New Hollands and that is a pretty common thing even on the older 56 & 6610
RodInNS
11-21-2006 18:01:26
My first thought would be a leaking head gasket. I would hope that it is a leaking head gasket. If it's not, then you're probably looking at a cracked block that is allowing oil from an oil gallery into the water jacket. Hope for a bad head gasket.... Check the oil passage that feeds the head, slightly left and forward of #1 cylinder. Are you absolutely sure that this is oil you're seeing and not a sheen of carbon from combustion gases entering the cooling system? Again, bad head gasket. BTW, when you have the head off, have it checked for flatness. If you don't have a precision straight edge, take the head to a head shop and have them check it for you. Good luck....
Rod
backhoeken
11-21-2006 19:31:18
 Re: Oil in Coolant in reply to RodInNS, 11-21-2006 18:01:26
Thanks . That is kinda what I thought but this is the first diesel I had. The 4500 and the 8n were gas
