Order Ford 3400 Parts Online
what do I have...3400?
BMurph
11-24-2006 10:48:34
I have a Bradco 660 that I'm told is a 3400 industrial. It looks just like one, but it has an 8 speed with an independent pto lever. I thought only the 4000's had the independent? I've got numbers on this thing, but I can't figure out the exact model from them. I'm trying to find what pto I need and what other parts might be missing because the pto's i've seen aren't long enough. Numbers are as follows: trans case-D5NN7006P rearend case-D7NN4024A motor block-D5NN6015G and number stamped above the oilpan rail is D293589. The numbers on the right front top of transmission are DU212K / 8D13B / C569655. Please help!! Thanks in advance. Bob
Rick from NC
11-25-2006 15:49:14
 Re: what do I have...3400? in reply to BMurph, 11-24-2006 10:48:34
BMurph,
Since you post is slipping off of page one without a reply I will give you my best guess.
A Ford tractor with serial number C569655 puts the tractor in the late 1970's. A build date of 8D13B means it was built on 4-13-78 on day shift.
'D' indicates it is based on the 4600. 'U2' tells the chassis type and I am not familiar with that designation. '1' indicates diesel. '2' indicates transmission driven pto. Are you sure it's an 8-speed? 'K' indicates 6 x 4 manual reversing transmission.
This is based on the earlier thousand series production code information so it may or may not be correct.
