Order Ford 801 Parts Online
801 SPINDLE THRUST BEARING
801 UNDER CONST
11-28-2006 06:34:01
I am rebuilding the front end on my 801 gas. The thrust bearings I ordered are part # A-CONN3123B.
These bearings won't fit in my spindle housing. The bearing DIA. is about .100 inch to big. Does anyone know what part # I need to order?
Thanks
murnga
11-28-2006 09:53:18
 Re: 801 SPINDLE THRUST BEARING in reply to 801 UNDER CONSTRUCTION, 11-28-2006 06:34:01
It would be my guess that the top thin shell of the old brg is still up in the housing.
Tim B from MA
11-29-2006 14:35:10
 Re: 801 SPINDLE THRUST BEARING in reply to murnga, 11-28-2006 09:53:18
probably common - when I rebuilt my front end a couple years ago, the bearing had been so mashed up (841 with a loader) that pieces of it (the internal race of the bearing I think) was indistiquishable from the steel of the spindle housing. I could not tell them apart till I cleaned the grease off and started digging with a chisel - I wasn't sure if I was wrecking something till the race came out.
801 UNDER CONSTUCTION
11-29-2006 04:33:26
That was it. They blended really good.
Thanks
Dave in Ms
11-28-2006 08:36:05
Since no one has replied yet I will give this a shot. My master parts book covers models from 53-59, and lists 2 different spindle pin thrust bearings. One is part# NCA-3123-A, for all except Heavy Duty from 53 on. The other is Refrence # 3123, part# 312631, Heavy Duty, except NAA, from 7-58 on. My guess is you have the heavy duty one.
HTH.
DonCam
11-28-2006 08:16:36
I looked up your front end and the part # you have is the correct part for both the power steering and manual front end as they are the same.
Is the bearing to big in the OD or ID, maybe there is some wear on which ever is the problem, the spindle or the bearing housing. The old one could have been locked up and spinning in place for a long time? Don't know but the part # you have is correct.
11-28-2006 08:39:55
 Re: 801 SPINDLE THRUST BEARING in reply to DonCam, 11-28-2006 08:16:36
The bearing fits over the spindle as it should. The outer DIA. will not fit the housing.
All input is appreciated.
Dave in Ms
11-28-2006 08:39:14
DonCam, you slipped one in there while I was'nt looking. :-)
